2004 S4 clutch blew apart--help
Dealer tells me my clutch blew into pieces and damaged flywheel. Pressure discs/plate were not very worn. Dealer says he doesn't know why it happened. Sorry, clutch is a wear item,not covered by extended wty. $3000 pls. BTW, he says, one of my motor mounts is broken.
So, my question is: could the failure of the motor mount have caused the structure to torque and twist and blow apart the clutch? If true, I have a wty claim.
thx
thx
Very doubtful - the way the clutch assembly is attached to the engine and mated to the transmission should keep everything aligned just fine. I doubt very much that the mount had anything to do with it.
