Coolant Change DIY?
Old 07-09-2008, 07:21 PM
mys4.org's Avatar
Default Coolant Change DIY?
I've been searching and I'm not having any luck? Any one know of a DIY for a B5 Audi S4 2.7t? I really need to know is if a 50/50 mix is ok? And more importantly how much coolant fluids does our system hold?
Any help would be awesome. Thanks!
Old 07-09-2008, 09:19 PM
ImTheDevil's Avatar
Default RE: Coolant Change DIY?
I don't think the s4 is different than the A4 in that regard but I don't know for sure. In my A4 it calls for 3 quarts of Pentosin (G12) coolant, and the rest water (basically a 50/50 mix). Most likely the S4 is the same.
Old 07-10-2008, 05:45 PM
mys4.org's Avatar
Also where do I drain the coolant out?
Old 07-11-2008, 11:11 AM
paparose_12's Avatar
Member
50/50 mix. Just did mine, it is pretty easy. If you go under the car, just about directly behind the passenger fog light there is a big hose with a clamp on it, one that fits in the grooves and pop that off and back the hose off, it drains pretty quick from there. Then I ran some water through the system to clean it out a couple times and filled it back up. Hope that helps
Old 07-11-2008, 06:55 PM
mys4.org's Avatar
Howmuch coolant did you need?
Old 07-13-2008, 09:48 PM
Member
did you get the answer to this, sorry my computer has been acting up
Old 07-15-2008, 04:45 PM
slow4's Avatar
Did mine last week and got a facial from my S.
The mixture IS a 50/50 mix, but be sure you utilize G12 Pentosin coolant. It will consume up to 3 gallons of it, so you'll need two 1.5g bottles.
Also, to flush the coolant system, I did the following:
Park car on my slanted hill driveway, with garage running flat.
Have car poke out of garage enough so there is clearence for you to get underneath the S.
Remove lower pass grill by foglights
Remove underbelly
Reach up between radiator and engine, and look for huge pipe connecting radiator to engine
Remove clasp for coolant sensor
Pull coolant sensor out
Coolant is flushed
Remember...DO NOT DO IT WHEN ENGINE IS STILL HOT and UNCAP COOLANT CAP.
Old 07-17-2008, 03:43 PM
bkcox_S4's Avatar
So 3 Gallons of Pentosin mixed equally with 3 gallons of water..?
or 1.5 of each?
Old 07-17-2008, 05:35 PM
ImTheDevil's Avatar
3 quarts of Pentosin, and the rest water - try 3 gallons and you'll end up blowing about $120 on coolant and end up with most of it on the floor of the garage.
vmaxie
03-24-2011 05:03 PM
jonjezak
02-26-2011 08:13 PM
PJ_RS1800
09-16-2010 11:08 PM
srlito
08-14-2009 10:20 AM
RollinA4
01-05-2007 05:23 PM
Quick Reply: Coolant Change DIY?
