Rotor removal question
Old May 16, 2009 | 03:29 AM
f_g_garcia's Avatar
Default Rotor removal question
Im trying to remove my front rotors from my B5 S4. I know how to take everything apart, but, i just ran into this little bolt looking thing that's in front of the upper caliper bolt. Does anything happen if i take it out? If i do and nothing happens, am i going to have to bleed it?
Old May 16, 2009 | 07:52 PM
bigern45's Avatar
dont take it out.. it looks like the rubber boot on the bleeder.. so leave it alone!!! take the two allen or torx screws out of the caliper and it should hang to the side.. then you can remove your rotors... to the very side of that you see a bigger rubber boot with some solid plastic end caps.. remove the caps and then get your allen 10mm i think could be 8 mm and remove that bolt.. theres another one on the bottom.. i just did this a few days ago..;-)
Old May 16, 2009 | 11:24 PM
derek072887's Avatar
if you don't know what that is you don't need to be touching your brakes.
Old May 16, 2009 | 11:32 PM
bigern45's Avatar
^^^++1..
sounds about right
Old May 17, 2009 | 04:13 AM
bottlecap's Avatar
cmon how is someone supposed to learn how to work on **** if you dont try. give him credit for doin his own work. these forums are here for situations like this
Old May 17, 2009 | 05:33 PM
a beginner needs to ask how to change the oil properly, NOT ask what a brake bleeder is... if you change your oil wrong and say don't fill it enough, you break your engine, if you don't do your brakes properly you can hurt or even kill yourself or others!!
Old May 17, 2009 | 06:32 PM
bottlecap's Avatar
psh thats what the ebrake is for
Old May 17, 2009 | 07:31 PM
im just glad he does't live in the same town as me.....
Old May 17, 2009 | 10:38 PM
drobrt's Avatar
I didn't know what that was either, and I'm not a newb to cars.
gabewatts1335
Oct 20, 2011 03:53 PM
omanalansan
May 17, 2009 06:56 PM
aloo
Nov 11, 2008 10:07 PM
paul.cadima@ge.com
Oct 19, 2008 06:49 PM
ein Silbern A4
Oct 16, 2006 05:19 PM
