Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
eibach coilover problems
Old Oct 30, 2008 | 08:46 PM
warranty225cpe's Avatar
Default eibach coilover problems
ive got an 04 tt225Q. i just installed a set of eibach coilovers. the problem is, there arent any places to mount the sway bar on the front shock body or frame. im thinking about making a bracket that will allow me to bolt the sway bar on. i might have to do a little gentle spot welding on the shock. i know its not recommended, but i dont have any other options. any suggestions would help.
Old Nov 10, 2008 | 08:38 PM
ImTheDevil's Avatar
I wouldn't do it to the strut body - sways mount to the hub/spindle so that the side loads that they see are transferred adequately. Mild spot-welding is probably going to break and doing so to the strut's tube may blow the tube out. I'd find a way to mount them to the spindle, even if that means drilling through it and bolting the sways to it.
Old Nov 10, 2008 | 09:26 PM
I had a bracket made out of an exhaust hanger. My boy welded up some nice hardware. We then just bolted it to the top of the strut housing. Works awesome! Check outthe thread in the TT section.
MacAudi4
Sep 5, 2008 12:29 AM
AUStex
B7 Models
Jun 8, 2008 05:21 AM
Figgy1682
Feb 9, 2008 10:32 AM
oliverlight
Apr 8, 2007 10:23 AM
ThePapaCMan
Jan 22, 2007 03:32 PM
