VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VAGCOM only working with limited modules
Old Aug 26, 2011 | 10:51 PM
rockblock's Avatar
Default VAGCOM only working with limited modules
Hi Folks,
I am using VCDS-Lite. I had a 1999 A4-B5 and I could pull almost all addresses, but I recently got a 2008 A4-B7 and I can only read the following addresses: 08/09/16/17/36/46/56. The ones I needed most (01/02/03) tell me the protocol is not supported. Does that mean that I need to use a separate interface? Is it possible I have a KII and need CAN? - which one do I need? Seems odd that I would have to use multiple interfaces to cover off a full scan.
Thx
Old Aug 27, 2011 | 11:07 AM
eMacPaul's Avatar
Yeah, sounds like you need a different cable. Audi has moved them to different protocols as the cars have advanced.
Old Aug 27, 2011 | 12:37 PM
rockblock's Avatar
Any clues as to which aftermarket ones one would work?
Old Sep 6, 2011 | 04:02 PM
o0timbo0o's Avatar
you need the Hex-Can cable.
Most of the electronics run on can bus on the b7 apart from some legacy stuff that was pulled over from the b6 ,
Old Sep 7, 2011 | 09:28 AM
redcon1's Avatar
I bought an ebay Hex-Can cable and I can't get it to link to the car at all with the current version of VCDS-Lite. The cable tests OK except for Latency - which comes in at 11-12ms, Poor. No communication with the Modules. I am running it on a small Netbook runing XP, I don't know if that's the problem or not.
Old Sep 8, 2011 | 10:31 PM
rockblock's Avatar
I just ordered a HEX-CAN from HK for $36 shipped - seller says it will work - I'll let you know how it works out
Ricston
Mar 23, 2014 08:11 AM
ericp1.8T
Oct 9, 2011 11:44 PM
markymarc
Sep 18, 2010 05:39 PM
outlaw24
Dec 16, 2008 08:03 PM
jude14601
Apr 23, 2008 12:07 PM
