bad seat heater..HELP!
Old Sep 23, 2007 | 09:04 PM
kemp_travis's Avatar
Default bad seat heater..HELP!
so i went to turn on my heated seat and found out it had no fuse...so i put the correct one in. And then my driver seat just started heating up even with the car off and the heat control on zero. and then i touched the control **** and it was hot as *****, and its plastic. So i took out the fuse asap. so now i think that there is obviously a short somewhere...but i have no idea what i should do. the **** was sooo hot and the seat stayed on...but turned off once i pulled the fuse.
help please
Old Sep 23, 2007 | 09:13 PM
auditech79's Avatar
Default RE: bad seat heater..HELP!
Its probably the switch, if it had a short to ground or something the fuse would blow immediately.
If the switch doesn't fix it your gonna have to break out the wiring diagram and chase each wire for power, ground, signals, ect. which should be reserved for someone that is certified to carry out those repairs.
HeyCesar
Mar 18, 2013 05:15 PM
mattbracing
Aug 28, 2007 12:38 PM
BoatsontheBrain
Jan 13, 2007 10:21 PM
gregp1962
Dec 18, 2006 09:34 AM
mclarensr
Apr 16, 2005 02:32 PM
