Brake Boost Fault
Either your brake booster needs to be replaced, or the vacuum hoses to the booster are loose.
Are you having any brake problems such as fade, or poor braking for the first minute after your car has been parked a while? If no problem, clear the code and recheck in a day to see if it re-appeared.
brake booster is center on back of engine - big black cylindrical thing left of the brake fluid reservoir.
There is a check valve that can blow apart.
here is a schematic - it's #7
