Brake Boost Fault
Old Oct 7, 2006 | 12:41 AM
ScAndal's Avatar
Default Brake Boost Fault
1 Fault Found:
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
Anyone have an idea how to resolve this?
ScAndal
Old Oct 7, 2006 | 12:56 AM
david9999's Avatar
Default RE: Brake Boost Fault
Either your brake booster needs to be replaced, or the vacuum hoses to the booster are loose.
Are you having any brake problems such as fade, or poor braking for the first minute after your car has been parked a while? If no problem, clear the code and recheck in a day to see if it re-appeared.
Old Oct 7, 2006 | 01:04 AM
ScAndal's Avatar
No braking problems as far as I can tell. I've reset it a few times and it always comes back.
Can someone take a pick of the vacuum hose? I have a 2002 A4 B6
ScAndal
Old Oct 9, 2006 | 03:19 AM
brrman's Avatar
brake booster is center on back of engine - big black cylindrical thing left of the brake fluid reservoir.
There is a check valve that can blow apart.
here is a schematic - it's #7
Old Oct 10, 2006 | 11:44 AM
ScAndal's Avatar
Awesome! thanks for the pic. I'll check it out.
ScAndal
Old Dec 2, 2011 | 03:35 PM
tonyblunte's Avatar
do you know the part #
Dogpile
Mar 20, 2020 12:54 PM
bradyhn
Jul 19, 2014 08:53 PM
ady_m
Oct 16, 2010 02:32 PM
jonny17
Mar 24, 2009 03:50 PM
Audiva
Jun 11, 2007 08:33 PM
