Dip Stick Help
Old Sep 3, 2007 | 01:53 AM
superfly78209's Avatar
Member
Default RE: Dip Stick Help
bump
Old Sep 3, 2007 | 02:54 AM
acetrebo's Avatar
Is there a plastic piece on top of the oil tube?
If so, maybe you already have it.
Otherwise, you want to make sure you are getting an acurate measurement.
maybe buy the $3 platic pieceand replace itand see if it seems normal. otherwise, you may have to do the dealer thang.
Good luck.
Old Sep 3, 2007 | 08:36 AM
david9999's Avatar
See my post 5 up. The dipstick guide frequently snaps off. Getting the rest of the old one off is a bit of a pain. You will need to cut it off with a dremel and a cutting wheel.
Old Sep 3, 2007 | 01:34 PM
Member
Well all I see is a metal pipe coming up for the oil pan. No yellow plastic or anything except the stuff that's on the dip stick. Thanks for the help guys.
Old Sep 3, 2007 | 03:55 PM
david9999's Avatar
The the hardest part is done. Just order a new one and the dipstick will measure fine.
Old Sep 3, 2007 | 04:22 PM
Member
Can u give me a link to which one I should buy? and I just clip it on and that's it. Right? Thanks
shaunk117
Jan 30, 2013 11:56 PM
exXU1
Jul 18, 2011 08:15 AM
_zero
Dec 1, 2009 04:02 AM
IDUA ORTTAUQ 6A
Sep 9, 2007 10:52 AM
joserv80
Dec 9, 2006 09:34 PM
