nitrous
ORIGINAL: sdboarder84
but the other ways are there ALL of the time, I do not want it there all the time. it would just be nice to have on those days where I want a near 300 horse monster. I am pretty set on it at this point, thanks for the input guys.
Just go BT. Keep the rpms under ~3400rpms, and you'll have no power, rev it to redline, and you'll have a 300+ hp monster.
I also researched crank pulleys and they just did not seem worth it. in terms of my exhaust it is a custom cat back 2 3/4in straight pipe. the reason I am shying away from the K04 is all the supporting mods that need to go along with the turbo ( injectors, FPR, and a Tune), not to mention the kit I am showing above can be bought for 550.00 dollars straight from the company and I have a hook up to fill my bottle so no worries about that. I really appreciate all of the feed back because this a big decision for me. Thanks again guys.
ORIGINAL: pyropenguin
that or go BT and get a MBC with two boost settings. set one for the monster and the other for the crusin
ORIGINAL: Bondga
for the cost of N20 i would just go k04, same power and you don't have to fill it up
Ok, back on subject. There is a guy ( ooanitpostoo ) in the TT section with a diode mod and runs a 100 wet shot and has done it numerous times. I would not personally recommend doing over a75wet shot and not injectingituntil ~4k rpm. But you will need to install a fuel pump and have your timing retarted 1* for every 25hp shot. So in this case, 2-3* would be fine. And finally, witha turbo car, this 55shot will actually net you around 60-65whp.
You should also check out NX's new drive-by-wire kitsince you have a 01+ car.
haha its called a Boost controller, you turn the **** and make an additional amount of hp depending on how much boost and how big your turbo is.
Its NOT always there, turbo is but power isnt.
Adam~
Adam~
Unorthodox Racing has a nice pulley that is popular!
Take a look at it im sure that would be a good buy for you.
021410602
Price:$205.91
Let me know if I can further help you!
Adam~
021410602
Price:$205.91
Adam~
ORIGINAL: ocadam
How much are crank pulleys? Does anybody on AF have one ive never seen a thread on it?
ORIGINAL: Adam@mvp
Adam~
Adam~
