Rear-Wheel Bearings???
Old Nov 15, 2005 | 07:43 PM
wombats3's Avatar
Default Rear-Wheel Bearings???
I have a '98 A4 2.8 that lately has been riding pretty rough. It's very loud now whenever I go anywhere. I basically sounds like it's not shifting, although it is - it just makes the noise like it's revving really loud. It's always loud, but it's at its worst when I'm travelling between 40 and 50 miles per hour.
I took it in today and they told me the right rear-wheel bearings need to be replaced. Does this sound right to you guys??
I just want to make sure before I pay to get it repaired. Thanks.
Old Nov 15, 2005 | 09:15 PM
CRAZYHAWK's Avatar
Default RE: Rear-Wheel Bearings???
Wheel bearing noise is speed dependent. If it makes more noise when you turn left, it is a right bearing.
Old Nov 15, 2005 | 09:17 PM
wombats3's Avatar
Is there any danger if I don't get that repaired right away?
Old Nov 15, 2005 | 09:40 PM
clconversion's Avatar
its not something I would leave for a long time if the sound gets louder the faster your drive and it is a humming sound in the rear most likley a wheel bearing its pretty common on our cars
Old Nov 15, 2005 | 09:43 PM
wombats3's Avatar
Stupid question - if I leave for another month or two, there's a chance it could damage the wheel further, but it couldn't get so bad it would fall off, could it?
Old Nov 15, 2005 | 09:45 PM
eventually it could heat up enough it could cause some real damage depends how loud is it now ? if it just started then leaving it for a month would be fine as long as you are not doing crazy miles
yellow_submarine
Mar 20, 2014 08:45 PM
Broncoman75
Jan 2, 2009 01:11 AM
zero388
Nov 28, 2007 07:53 PM
onepoint8tee
Jan 7, 2006 04:33 PM
Dhenkel
Jul 11, 2005 03:58 AM
