v-tech?
Old Sep 18, 2006 | 08:22 PM
  #41
nstotal's Avatar
Default RE: v-tech?
Actually, vtec kinda is magical and is NOT the same thing as vvt that you guys are talking about. Variable Valve Timing for our cars and for toyotas uses electronic camshaft timing adjustments to increase or decrease the duration of the camshaft for different low/high settings. Vtech actaully has another camshaft lobe with another profile on it that is switched over to at higher rpms. Vtech is alot different from VVT, but they both have the same idea behind them.
Old Sep 18, 2006 | 08:24 PM
  #42
TurboQuattroPwr's Avatar
Default RE: v-tech?
Blah, blah, blah, blah, THE END.
Old Sep 18, 2006 | 09:34 PM
  #43
a3_yuppie's Avatar
SoCal Crew Member
Default RE: v-tech?
NSTotal and Bongda are the only ones who have any idea of what VTEC is. The latest VTEC, dubbed i-VTEC by Honda, has BOTH VVT as well as different cam lobes (hence the "lift") whereby at a certain RPM the camshafts operate on another set of lobes to open the valves more and for different durations to improve engine breathing. Bash ricers and bad taste all you want, but at least understand the technology.
Old Oct 2, 2006 | 03:26 AM
  #44
AudiTurbo's Avatar
Default RE: v-tech?
THERE IS NOT H IN VTEC. AND HONDA VTEC IS VARIABLE VALVE TIMING AND ELECTRONIC LIFT CONROL. VVT IS JUST VARIABLE VALVE TIMING. BIG DIFFERENCE.
Old Oct 2, 2006 | 03:38 AM
  #45
Karl's Avatar
Default RE: v-tech?
Hey you Necro bumper!! First off dont yell.. second off.. dont necrobump!! Got it??
Old Oct 2, 2006 | 04:04 AM
  #46
evoic's Avatar
Default RE: v-tech?
And the beee-yotch slap commeth.
Old Oct 2, 2006 | 05:03 AM
  #47
B7AudiA4's Avatar
Default RE: v-tech?
You guys drive me nuts when you guys say V-TECH
HAHHAA
It's VTEC (Honda/Acura)
VVT-i/VVTL-i/VVT (Toyota/Lexus)
Are you sure he wasn't talking about FSI!!![&:]
Draklore
B7 Models
Oct 11, 2009 11:24 PM
Retard Riot 686
Mar 19, 2008 07:39 PM
new2me
Mar 31, 2007 10:14 PM
rbrtech
Jun 15, 2006 03:32 PM
