Sponsored by:
Sponsored by:
Battery Problem or NOT ?
Old 12-23-2005, 01:06 PM
Hove_06902's Avatar
Member
Default Battery Problem or NOT ?
Hi
I have a 98 A6 2.8 Quattro lately the car have been dying not able to start in the morning or in the middle of the day. Sometimes I charge the batterry & it will run fine for a couple of days & after & die again. I thought it was the battery problem, but I recharge over & over the power on the battery it's fine. So anyone whom have that problem & was able to fix respond with a few ideas on what to do.
Thanks
Happy Holidays.
Old 12-23-2005, 08:38 PM
beefski's Avatar
Default RE: Battery Problem or NOT ?
have the battery laod tested. could be alt also
Old 12-24-2005, 12:11 AM
heisse_mkII's Avatar
I'm not sure on Audi's but it could also be your voltage regulator. But I think in the newer cars, they are built into the alt. so you'll have to replace the alt. Also get your battery checked out, because if this happens for a while, then you'll have to replace the battery also becaue it won't want to hold a charge.
Old 12-26-2005, 11:31 AM
misko's Avatar
dont forget to check the water in the battery, some that are said to
be maintainance free are not and will not hold a charge long without
water(distilled h2o only please)
Old 12-26-2005, 09:17 PM
jukeit's Avatar
Had a similar problem the first year I had my car. Turned out to be the battery. Just wouldn't hold a charge for very long.
nimmy
03-17-2015 07:53 PM
Theghost_85
02-02-2011 11:19 PM
peeties
06-09-2010 04:01 PM
cooltime7
11-07-2008 03:06 PM
silver_rings
07-21-2005 11:16 PM
Quick Reply: Battery Problem or NOT ?
