Total Hose Replacement on Vacuum System
Old Apr 29, 2009 | 01:57 PM
  #41
danmcc86's Avatar
HA HA! put so well!
Old Sep 3, 2009 | 12:56 PM
  #42
tedsAudi's Avatar
Default IMT valve vac hose
Hello all,
i replaced my vac lines also , all except the one thats shown as imt valve.
Could not see if I could just pull the vac hose out of it and did not want to
remove the whole assembly in order to take a better look in case I
mess with some alignment of it.
How do you change the vac hose on this?
thanks
Regards
Ted
Old Nov 2, 2009 | 10:55 PM
  #43
danmcc86's Avatar
sorry Ted, just saw your post, I did not replace that hose for the same reason you stated. from what I saw it wasn't in as bad shape as the others.
Old Nov 3, 2009 | 07:00 PM
  #44
hxgaser's Avatar
I had to remove the imt valve itself to replace the hose. Wasn't that bad. Just had to remove the coil assembly. One thing is I dropped a torx bit down under the intake and could not fish it out. As far as I know, it is still there...
redmond1501
May 12, 2014 02:55 PM
A4TurboGuy
Oct 15, 2013 10:07 AM
a2thy
Jan 6, 2010 01:49 AM
Badman
Sep 15, 2009 10:31 AM
bottlecap
Apr 5, 2009 07:04 PM
