Problem with suspension
Just my experience.......In most cases a burned out relay is CAUSED by an outside source, such as the compressor failing. Same as a blown fuse, 99% of the time it is not the fuse that failed but a short to ground in the circuit or the device is failing and drawing too much current.
My A8 D3 front suspensions compressor and valves were changed two years ago due to a leak . Recently I notice the green suspension light on the dashboard lit up for a few seconds and disappear. This usually happens when the car is stationary and the car is on comfort setting. The car was service four months ago and the mechanics said the suspensions are fine as their ross tech software shows no fault. Other than that the rest of the suspension function correctly. Is this a sign of a leak or just normal
