Factory bov noise?
Old 07-08-2011, 03:57 PM
Ryanwillbuyit's Avatar
Default Factory bov noise?
I have a 2000 a4 1.8t quattro n I hear a small air release wen I get on it from 1st to 2nd n its an automatic. It's all stock. My dv go bad?
Old 07-08-2011, 10:46 PM
ImTheDevil's Avatar
You may be hearing the DV dumping surge air back into the system. If you're not seeing a CEL and the car pulls nicely after you get off it and jump back on, then your DV is working right.
Old 07-15-2011, 06:51 AM
What's CEL?
Old 07-15-2011, 07:38 AM
ImTheDevil's Avatar
CEL = check engine light
Old 07-15-2011, 06:11 PM
BigErk77's Avatar
the diverter valve should only come into play when you let off the accelerator.
Old 07-16-2011, 02:45 PM
poopsman's Avatar
yeah i hear that too anytime i shift gears around 0-5 psi, mine has a check engine light on, problem was system to lean or something like that idk, car runs just fine, sounds like a butterfly bov.... is there a way to make it louder?
Old 07-17-2011, 05:43 PM
Tweaked's Avatar
If it's making noise, you need a new hooter valve.
Replace the diverter valve and the vacuum line to the DV. When you go to the dealer, ask for the TT 225 version of the DV, it's a lot cheaper than the "stock." Replacing the DV with a BOV or leaving it open will cause rich dumps between shifts, causing the check engine light to come on eventually.
rahip4567
B8 Models
11-13-2019 04:04 AM
Schlampah
01-27-2011 08:24 PM
tj19855
12-31-2007 03:28 AM
ZIV3R
09-20-2007 02:02 PM
tbrown
09-11-2006 02:47 PM
Quick Reply: Factory bov noise?
