Not Starting, Cranking, but NOT starting.
Old Jun 21, 2011 | 08:27 PM
cvbadass's Avatar
Originally Posted by makhack
ECU Relay? Or you mean Fuel Pump Relay?
I order fuel pump relay, picking it up in ad day or two. Will let you know what happens.
By the way witch is the ECU Relay?
Ecu relay is in the ECU box under the hood, for me it was relay #30. I had replaced the fuel pump, relay, ignition switch, crank sensor, and coils, only to find out it was the ECU relay. But my car would start randomly. It could be your Crank position sensor, if it never starts.
Old Jun 22, 2011 | 01:30 AM
makhack's Avatar
Originally Posted by Dallas09
Does the check engine light come on when you turn the car to on?
Good Catch Dallas09. I just check and NO the check engine is NOT on. Any Ideas?
I will try to post a new thread in B5 with few pictures and if you have any ideas let me know. Thanks a lot.
Old Jun 22, 2011 | 08:56 PM
Dallas09's Avatar
That basically means no power to the ECU, so check fuses relays, connections etc., otherwise from what Ive read, its either a bad chip (if you have one) or a bad ECU.
Old Jun 23, 2011 | 04:04 AM
beat180's Avatar
easy to check relays. look at the pin diagrams on the relay, they're numbered. the parts with the / are the switched pins, so when you put 12v across the triggering pins, you'll hear it click and now you'll have continuity across the switched pins. Use a multimeter for this or have a test light to check for this.
I took an old AC adapter to some electronic device that didn't work anymore to make my test setup for the relays for my car's starting problem from just a few days ago. That might help you isolate which relay went kaput.
Old Jun 23, 2011 | 04:24 AM
makhack's Avatar
Default Problem Solved, but new problem arises
Problem Solved, but now I got a new problem. I found that fuse # 32 - Engine timing 20A is burnt. What would cause the Engine timing fuse to burst? Any ideas?
Old Jun 23, 2011 | 12:42 PM
beat180's Avatar
it's shorting out somewhere. time to bring out the multimeter and find where it is.
josearey
Feb 2, 2012 11:52 AM
audia4crap
Apr 21, 2011 08:59 PM
Caddy
Apr 13, 2011 09:50 AM
DtmDave
Feb 24, 2010 03:57 AM
TigerGomes
B7 Models
10
Apr 20, 2009 06:38 PM
