Transmission 4th gear slip "problem found"
Old Sep 16, 2012 | 11:34 AM
  #21
mrk3cobra's Avatar
Some more pictures. I should be done with the rebuild today and ready to install back in the car
Attached Thumbnails Transmission 4th gear slip "problem found"-dscn2732.jpg   Transmission 4th gear slip "problem found"-dscn2733.jpg   Transmission 4th gear slip "problem found"-dscn2734.jpg   Transmission 4th gear slip "problem found"-dscn2735.jpg
Old Sep 16, 2012 | 01:31 PM
  #22
Nemick's Avatar
Very thorough job you're doing there. I hope it works out well for you. Well done!
Old Sep 17, 2012 | 07:37 PM
  #23
mrk3cobra's Avatar
Transmission rebuild done. Started installation in the car on Sunday, should be done in a couple of days.
Attached Thumbnails Transmission 4th gear slip "problem found"-dscn2737.jpg   Transmission 4th gear slip "problem found"-dscn2738.jpg   Transmission 4th gear slip "problem found"-dscn2739.jpg   Transmission 4th gear slip "problem found"-dscn2740.jpg   Transmission 4th gear slip "problem found"-dscn2741.jpg
Old Oct 23, 2012 | 09:19 PM
  #24
mrk3cobra's Avatar
After having some problems with the rebuild, I had no reverse grear and a few other issues. Search" transmissiuon help" I had to open the transmission back up. I found what the problem was it had to do with installing the last part in the rebuild the oil supply unit and brake C clutches.. The manual says to use a special allighnment tool, but who has this. I resolved the problem and the transmission works great.
If you are thinking of rebuilding the transmission yourself I can give some good advice on what not to do.
If you need help just send email.
If anyone needs the ZF rebuild manual I have one for sale.
Pete
Old Oct 25, 2012 | 01:08 PM
  #25
blackarachnid87's Avatar
..... Pm'd
Old Feb 12, 2020 | 07:44 AM
  #26
Matt Mankinen's Avatar
I recently got a 99 A4 Quattro with a bad transmission, then ran across this old posting. I already have a replacement transmission and was wondering if it's common for the torque converter to wear out also? From what I understand from the previous owner they started losing gears. Of course a new TC would be wise but just trying to save money for other things the car may need.
Old Feb 17, 2020 | 04:02 PM
  #27
John_E's Avatar
Zombie thread, I know, but very interesting and informative.
Old Feb 26, 2020 | 06:09 PM
  #28
Found I need another TC so if someone has a good used one for sale please let me know.
Old Mar 11, 2020 | 02:30 PM
  #29
Cybersombosis's Avatar
I have one but I’m up in Canada.
Doug
cas5259
Jun 27, 2013 03:56 PM
PluschakovP
Apr 21, 2010 06:50 PM
9idua7
Apr 29, 2009 11:56 PM
mikes_tt
Sep 25, 2008 10:42 PM
aron56
Jan 2, 2008 08:20 PM
