Trying to get my VCDS-Lite to work.
Old Jan 10, 2011 | 07:50 PM
Mad Cow's Avatar
Again what version of vagcom do you have? You need 409.1 for that cable. And by test I mean when you go to the options menu, select whatever port you're using and press the test button. A window should pop up with the results. I never had any luck with that cable, I even went as far as installing XP on another partition and it just didn't want to work. Did you change the port in device manager?
I just gave up after a couple of days screwing with it, returned the cable and bought a 908.1 cable, which was completely plug and play.
Old Jan 11, 2011 | 09:00 AM
pbbg's Avatar
Originally Posted by dragonrage
32-bit or 64-bit Vista? Have you checked the device properties for the USB-serial converter device?
i believe i choose 64 bit vista. what should i be looking for in the device properties.
Old Jan 11, 2011 | 09:01 AM
pbbg's Avatar
Where can you get 409.1? I will try those other things on the cable.
Old Jan 11, 2011 | 08:34 PM
Mad Cow's Avatar
No way to get it legally, you'll have to figure that out yourself. Also, good luck if you have 64bit Vista, drivers and buggy and the software is outdated and buggy on 64bit Windows. Did the cable come with a CD? If it did it should have the right version or vagcom on it.
Old Jan 11, 2011 | 11:10 PM
hauptjr's Avatar
OK. I have a cheap cable and it was a pain, but I did get it to work.
I had to go into the device manager, and go to ports, and play around with com2 and com3. (USB means Universal Serial Bus. Serial ports are com ports - or more accurately, com ports are serial ports).
When I went into VCDS-Lite, options, test - I tried all of the com ports and took the com port that had the least latency.
Also - what else do you have configured on your computer? Hotsync, Blackberry sync and other sorts of apps will mess with com port settings. Also you might have to disable your virus scanner (but probably not).
Before you make changes, take notes as to what you are changing - just in case you need to change it back later.
Theres a certain amount of trial/error to get it to work.
Good luck
Old Jan 12, 2011 | 12:13 PM
pbbg's Avatar
alright a friend of mine purchased the full version about a month ago so i am going to use his for the time being but i will keep playing with this.
thomaseeTT
Mar 5, 2013 11:02 PM
Sheasta
Jun 30, 2012 05:15 PM
krazzz
Feb 21, 2011 08:41 AM
exequiel3k
Aug 22, 2010 12:49 AM
hauptjr
Apr 6, 2010 12:03 AM
