wallet emptying airbag light
Old Sep 25, 2010 | 01:31 AM
aussie_a4's Avatar
Default wallet emptying airbag light
Hi all
Im having an issue with the dreaded airbag light - its seems to be intermittant - sometimes it doesnt come on, other times its on for a couple of minutes then off again.., its done this ever since it went into BMTS in Brisbane to have the ignition barrel replaced, but they always swore it had nothing to do with them, and they wanted to charge to look at it again.
Ive checked as much wiring as I can and all seems fine, ive got half the dash out now checking the sensor module wiring - nothing amiss there
Has anyone seen this before?
Cheers
Old Sep 25, 2010 | 03:38 AM
Dallas09's Avatar
Do you have any codes under airbags or instrument cluster? You need a VAG. If it is intermittent like that, it sounds like a communication issue between the airbag computer and the instrument cluster.
Old Sep 25, 2010 | 01:37 PM
markymarc's Avatar
I am now an airbag expert....read this thread:
https://www.audiforums.com/forum/sho...d.php?t=155202
If you need photos of plugs and where things are, let me know...here are some other links as well:
Underseat airbag photo wiring:
https://www.audiforums.com/forum/alb...&pictureid=500
VERY good write up:
http://www.ozaudi.com/forums/showthr...-warning-light
http://forums.subdriven.com/showthre...ge2&p=66358208
THis one is good too:
http://forums.audiworld.com/archive/...t-1603277.html
http://www.fankhauser.info/airbag2.JPG
http://www.fankhauser.info/airbag1.JPG
Hope all these help. You WILL need a VAG COM to clear the airbag light.....if you need more help, post here or PM me...
Marky
Old Sep 25, 2010 | 01:52 PM
markymarc's Avatar
Sorry, I misread...if your LIGHT just blinks on and off, I'm going to say and agree with Dallas, it's a lose wire somewhere...probably happened when you had your ignition replaced...yes, they will NEVER admit it, but that's probably what happened...I can email you a diagram of how to take apart the whole inside of an a4, however, it's in GERMAN, but has a ton of pictures with locations of screws, harnesses etc on it....
Old Sep 25, 2010 | 02:48 PM
Andrew149's Avatar
it can be the passenger seat theres a wire under there thats cut too short and gets loose somtimes
Old Sep 25, 2010 | 06:46 PM
ImTheDevil's Avatar
Agreed on an intermittent communications wire. If it was an intermittent airbag wire that light would be on and stay on. It doesn't extinguish itself, even after a problem is repaired - it has to be turned off via scantool. If it's going on and off, it's a fault with communication or the airbag controller itself.
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
jdahlen24
Jan 28, 2011 08:49 PM
