04 A4 problems started then would die and now doesn't crank
Old Jan 15, 2009 | 08:35 PM
quigs's Avatar
Default 04 A4 problems started then would die and now doesn't crank
My sister lives in Colorado and called in a panic. She picked up a 04 A4 1.8l turbo 6spd quattro a few months ago and she is stuck at work because the car would not run.
She told me that the service engine light came on and said it needed to be serviced in 200miles then 100miles and then it would start and die immideatly. She kept on trying to start it and I had her check the fuses (she said they are all good). Then her fiance thought that it might be the battery so they hooked up the jumper cables and now it wont even crank over.
Has anyone ever run into this or heard about this happening or know where I can find the manual or tbs on her car
Thanks in advance
Phil
Old Jan 16, 2009 | 08:33 AM
Myst420's Avatar
Have you tried disconnecting the battery and waiting a minute or two, then reconnecting it? This will reset the computer.
Old Feb 22, 2010 | 03:20 PM
quigs's Avatar
I noticed that I never replied to this thread after I figured it out. The fuel pump died (@ 40K miles). And the battery was weak so she killed the battery by cranking it over.
Old Feb 22, 2010 | 03:46 PM
shane.trammell's Avatar
Hope she also replaced the fuel filter.
Old Feb 23, 2010 | 10:31 AM
quigs's Avatar
Yup, replaced the filter and at about 45k miles had to replace the vehicle speed sensor.
josh0327
Feb 19, 2015 02:42 AM
Hondakids-A4
Feb 4, 2013 01:35 AM
m41n5t4y
Apr 9, 2012 03:58 AM
Shizzle
Apr 7, 2007 08:31 PM
