Oil Control Rings broken, MASSIVE oil leak. Please help.
Old Mar 13, 2011 | 12:13 PM
adamike's Avatar
Default Oil Control Rings broken, MASSIVE oil leak. Please help.
Anyone ever hear of this?
Oil control rings leaking behind timing cover.
$2550 repair bill. ($1250 labor, $1300 parts)
Can't find anything on these parts or problem. Don't trust the dealer. Please help.
-03 Blue/Blue AT, 102,000miles
Old Mar 13, 2011 | 03:41 PM
mr peepers's Avatar
Oil control rings? I'm curious about that as well. I just finished replacing the camshaft adjuster gasket, which is what the dealer told me was the cause of my massive oil leak. Put it all back together, put on new cam bolt plugs as well, started up and ran perfect. Took it around the block a few times, parked it in the garage and oil is running all down the front of the engine still. Looks like I didn't even do anything.
I'm going back in later this week to replace the camshaft adjuster seals which I believe are the rubber o-rings on the actual adjuster itself? The only other seal behind the timing cover that I know of are the front camshaft seals which I may just replace too since I'll be in there and don't want to rip the whole thing apart for a third time.
$1300 in parts seems absolutely ludicrous. Audi wanted to charge me $1700 for the adjuster gaskets, which are $20 a piece, and I needed two since I have the 3.0L.
ETA: Where is your oil leak primarily? Is it accumulating below the main crank pulley? That's where mine is ending up, but I can see oil lining the timing belt covers and must be originating up towards the top of the engine, I'm assuming by the camshafts.
Old Mar 13, 2011 | 05:20 PM
Audi Tek's Avatar
Tech Certified
Yea, If your oil rings are broken your screwed...... You can throw that estimate out the window.
Cause the pieces will spin and chew up the tensioner assembly and even dig into the head. Causing massive oil leak.
Worst case senario is replacing the head and tensioner.
Hopfully the bolts just came out and all you have to do it replace the cam sprocket and tensioner gasket.
But you'll never know until the entire front of the motor is taken apart. Which is 4 hours of diagnosis you'd have to commit to without even knowing the extent.
what i'm curious about... is how the dealer knows its the rings.... You can't see them. The rings are not common failure, unless a repair was made prior and someone screwed up installing them.
nrf1211
May 15, 2010 08:05 PM
bshannon1
Jun 2, 2009 12:19 PM
Devin-B
Nov 7, 2008 01:07 AM
Sidewayzracer
Nov 2, 2008 05:00 AM
sam.T.
Feb 12, 2007 10:38 AM
