starting
Old Feb 14, 2008 | 01:03 PM
tml's Avatar
tml
Default RE: starting
well this morning it was -6 & the car started with out any problems...it's kinda pissing me off on what the problem was earlier
Old Feb 14, 2008 | 07:49 PM
M¥§T's Avatar
It could be some chipped teeth on the flywheel and when the car stops at that exact point the starter isn't making enough contact to turn it (which would also explain the grinding noise you mentioned)
Old Feb 15, 2008 | 08:49 PM
tml's Avatar
tml
it's looking more & more what u guys were saying....chipped flywheel....last dozen starts have been fine....also I might add...a few times in the past the first crank it would not start..2nd it would...other times it would take 3 or even 4 cranks to start...any Idea on how much this would cost to fix? & if this should be fixed asap...or if I can wait a bit..thankx!
Old Feb 18, 2008 | 05:33 PM
tml's Avatar
tml
bump ..anyone?...oh & now the car seams to start no problem.............
Old Feb 18, 2008 | 07:08 PM
M¥§T's Avatar
If its chipped teeth on the flywheel then you need to replace it. The longer you wait to fix it the more damage you do to your starter everytime you hear that grinding noise.
Old Feb 18, 2008 | 09:38 PM
tml's Avatar
tml
ok.,..but what would a job like this cost? also the car has been starting fine last 3-4 days..no grindng
makhack
Jun 23, 2011 12:42 PM
Audcura
Mar 9, 2010 11:48 PM
jojoenglish85
Feb 2, 2009 03:30 PM
Honda882000
Dec 27, 2007 10:37 PM
doubleDee
Sep 18, 2007 07:27 AM
