outer axel boots
Old Jun 25, 2008 | 08:10 PM
kingtut's Avatar
Default RE: outer axel boots
You're warranty won't do jack. That's why I think aftermarket products are a crock.
I'd say 250.00 is on the low/cheap end and 350.00 is on the high/expensive end...just my opinion
Old Jun 29, 2008 | 08:30 PM
matasci's Avatar
cv boot dont need to be replace that often. just wait untill they are actually damaged. you can buy the kit from autozone for like 60 dollars for both outer and inner. the dealship just recomends it because thats their job to find things wrong with the car while servicing it. theyll tell you drive belt need to be replaced befor they need ect. 30,000 is a little earlie for cv boots to be going out. my boots just busted at 140,000 and the avarage life for em is 60,000. but dont have the dealership do em its just rediculious.
you would need a jack, a vice, bronze punch to seperate the outer axels and take them apart. clean them and regrease them. some torx bits to take the half shafts off. basic tools to take off what ya gotta to get em off. its not hard at all. save yourself some money. make sure to mark where you disassemble the tie rods or control arms to avoid getting an allignment.
get an aftermarket manual and itll show you how to do it.
good luck and dont let the dealerships take advantage.
Old Jun 29, 2008 | 08:43 PM
ImTheDevil's Avatar
One thing to note - don't use torx bits on the axle mount bolts (where the axle joins the diff) - they'll strip out. You want triple-square bits (or 12-point bits, pick your name for them). A set of them is around $15 from ECS Tuning. I ordered it and it included 6, 8, 10, and 12mm I believe (the 8mm are the ones for the drive axle bolts).
Old Jun 30, 2008 | 12:24 PM
matasci's Avatar
thats right i forgot about the triple square. i had to get some fast to do a hub assembley for a new jetta. and the only place i could find em was snapon truck i got 3 for 90 i wasnt to happy. good call drilling out stripped bolts is no fun!
danstr1
May 8, 2009 11:41 PM
paaudia6
Jan 27, 2008 04:43 PM
TDRILL
11
Dec 21, 2006 10:28 PM
