Failing Emissions
Old Jan 23, 2013 | 08:39 PM
Juliet's Avatar
Default Failing Emissions
HELP! My 2001 Audi S4 will not pass emissions......I've had the O2 sensors replaced, vacuum hose leaks fixed, coolant temp sensor replaced, and new spark plugs......Still won't pass. The diagnosis codes are 1127, 1129 and 0300. What would you do next?
Thanks!
Old Jan 24, 2013 | 01:22 AM
TN69's Avatar
Those emission results would help... you can figure out things from them.
Old Jan 25, 2013 | 06:04 PM
FonzoB5S4's Avatar
0300 is a random misfire code. most likely the coilpacks. the other two refer to you running rich in both banks. i would think this is due to a boost leak, vaccuum leak or a really dirty/clogged air filter.
do a boost leak check.
http://www.awe-tuning.com/media/pdf/...ure_tester.pdf
pick-up some coil packs.
these are the oem ones:
Audi B5 S4 2.7T > Engine > Ignition > ES#8037 Ignition Coil - Set Of Six - 058998105
third party:
Audi VW Ignition Coil (Set of 6) - Karlyn STI 058905105X6 | FCP Euro
Also clean out your MAf with some Maf cleaner. hope this helps.
dtopland
Aug 27, 2013 10:31 AM
Fishvt
Apr 10, 2013 12:06 PM
Msnickbroderick
Feb 8, 2011 03:37 PM
loach1
Apr 13, 2009 07:39 AM
memzback
Mar 18, 2007 03:55 PM
